orangepir1-pluslts
Community maintained
  • Images for non LTS version can be downloaded here
  • There is currently a known issue that may affect this board on some IPv4 only networks. Symptoms are variable, from intermittent drop-outs and slow-downs to total loss of one NIC or total loss of networking. The issue can be completely eliminated by disabling IPv6. Don’t try to do this through armbian-config as this method does not work. IPv6 must be disabled by adding a line extraargs="ipv6.disable=1" to /boot/armbianEnv.txt
  • Device tree overlays to enable uart1 and i2c0 are available in Armbian 23.02.
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 438.9 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 266.4 MB
1000tx 4 core 64bit UASP usb-c wireguard Rockchip RK3328
