orangepi3-lts
Community maintained
After you download and boot?
armbian-config
Build Date: Apr 10, 2025
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.2 GB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 233.1 MB
Dedicated applications images with Armbian Linux v6.6
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 304.9 MB
1000tx 1wire 2GB 4 core 64bit UASP bluetooth docker eMMC i2c spi spi flash usb-c usb3 wifi wireguard Allwinner H6
