Community maintained
  • USB3 sometimes doesn’t detect high-speed devices properly
After you download and boot?
armbian-config
Build Date: Apr 10, 2025
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.2 GB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 234.7 MB
1000tx 2GB 4 core 64bit bluetooth docker eMMC i2c i2s spi flash usb3 wifi wireguard Allwinner H6
