Notebook
Community maintained
arm_64 via UEFI/BIOS for generic virtual board
Usage: Use this board to run armbian on a virtualized environment (eg: QEMU/KVM)
Differences with the ‘uefi-x86’ board:
  • support kernel boot messages on graphical and console/serial devices
  • support prompt on graphical/console devices
  • patches targeting virtualized env on x86 should be added here – when it make sense
After you download and boot?
armbian-config
Generic aarch64
Build Date: Apr 21, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT (QCOW2) rolling 6.12.24 SHA  ASC 796.7 MB
Ubuntu 25.04 (Plucky) Minimal / IOT (U-boot bin) rolling 6.12.24 SHA  ASC 352.3 KB
