x86_64 via UEFI/BIOS for generic virtual board
Usage: Use this board to run armbian on a virtualized environment (eg: QEMU/KVM)
Differences with the ‘uefi-x86’ board:
- support kernel boot messages on graphical and console/serial devices
- support prompt on graphical/console devices
- patches targeting virtualized env on x86 should be added here – when it make sense
After you download and boot?
armbian-config
- join community forums
Build Date: Apr 21, 2025
Minimal / IOT (QCOW2) | rolling | 6.12.24 | ![]() | SHA | ASC | 801.9 MB | |
Minimal / IOT (U-boot rom) | rolling | 6.12.24 | ![]() | SHA | ASC | 368.1 KB |
