After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Gnome | ![]() |
SHA | ASC | 1.2 GB | ||||||
Server images with Armbian Linux v6.6
Build Date: Nov 25, 2024
Server / CLI | ![]() |
SHA | ASC | 454.1 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 241.9 MB | ||||||
SHA | ASC | 232.6 MB | ||||||
SHA | ASC | 269.1 MB | ||||||
- join community forums
