Rock5 ITX
Standard support
Desktop
Armbian 26.2.1 Gnome
Kernel: 6.1.115, Size: 1.1 GB, Release date: Mar 14, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.1.115, Size: 271.9 MB, Release date: Mar 14, 2026
Build Date: Mar 14, 2026
Most stable mainline based kernel but not all features have been implemented yet.
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.4 GB
Based on Rockchip BSP. This kernel is newer than the legacy kernel v5.10.y and works stable too.
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 295.3 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 302.7 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 255.6 MB
Debian Testing (Sid) Kali Linux SHA    ASC 543.8 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 547.6 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 387.5 MB
Rockchip RK3588
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 293.9 MB
Ubuntu 24.04 (Noble) Gnome stable 6.1.115 SHA  ASC 963.5 MB
