After you download and boot?
armbian-config
Build Date: Feb 26, 2025
Cinnamon | ![]() |
SHA | ASC | 1.4 GB | ||||||
XFCE | ![]() |
SHA | ASC | 1.3 GB | ||||||
Gnome | ![]() |
SHA | ASC | 1.2 GB | ||||||
XFCE | ![]() |
Server images with Armbian Linux v6.1
Server / CLI | ![]() |
SHA | ASC | 454.5 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 236.5 MB | ||||||
SHA | ASC | 231.2 MB | ||||||
Build Date: Mar 6, 2025
Distro | Application | Torrent | Integrity | Size | ||||||
Home Assistant | ![]() |
SHA | ASC | 315.4 MB | ||||||
- join community forums
Build Date: Apr 21, 2025
Minimal / IOT | rolling | 6.1.115 | ![]() | SHA | ASC | 250.8 MB | |
Minimal / IOT | rolling | 6.1.115 | ![]() | SHA | ASC | 259.2 MB |
