Radxa Zero
Community maintained
If you have a Radxa Zero with eMMC (any model with 2GB or 4GB of RAM), you’ll need to erase the eMMC before you can boot it from a microSD card and use Armbian. 1GB version is not supported.
Full instructions are available on the Radxa wiki, but here are some quick notes.
– Connect a USB cable to the Zero’s OTG port (the USB-C plug marked USB-PWR)
– Hold down the “USB BOOT” button on the Radxa Zero while connecting the USB cable to a USB port on the Linux host
sudo pip3 install pyamlboot on the host
curl -O https://dl.armbian.com/radxa-zero/loader/radxa-zero-erase-emmc.bin
sudo boot-g12.py radxa-zero-erase-emmc.bin
You may have to run the sudo boot-g12.py command a second time to fully clear the eMMC. In case you encounter boot issues, try this hint and report there.
After you download and boot?
armbian-config
Build Date: Nov 24, 2024
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 241.9 MB
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 324.9 MB
2GB 4 core 4GB 64bit bluetooth docker eMMC i2c spi usb-c usb3 wifi wireguard Amlogic S905Y2
