Community maintained
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 305.7 MB
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 302.4 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1 GB
Debian Testing (Sid) Kali Linux SHA    ASC 501.1 MB
Rockchip RK3566
