radxa-zero2
Community maintained
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 269.6 MB
4GB 6 core 64bit bluetooth docker eMMC i2c spi usb-c usb3 wifi wireguard Amlogic A311D
