Picture of a Rock5B
Standard support
Minimal
Armbian 25.8.2 Bookworm Minimal / IOT
Kernel: 6.1.115, Size: 253.3 MB, Release date: Sep 25, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.8.2 Noble Gnome
Kernel: 6.1.115, Size: 1.4 GB, Release date: Sep 25, 2025
UART
GND (pin 6) <—> Black line
TX (pin 8) <—> White line
RX (pin 10) <—> Green line
After you download and boot?
armbian-config
Build Date: Sep 25, 2025
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.2 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.3 GB
Debian 13 (Trixie) Cinnamon SHA    ASC 1.4 GB
Debian 13 (Trixie) XFCE SHA    ASC 1.4 GB
Debian 13 (Trixie) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 538.3 MB
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 531.1 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 261 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 272.8 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 286.9 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 252.1 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 268.5 MB
Build Date: Sep 23, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 340.4 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1.2 GB
Debian Testing (Sid) Kali Linux SHA    ASC 723.1 MB
1000tx 100tx 16GB 1wire 2500tx 2GB 32bit 4 core 4GB 64bit 8 core 8GB Closed bootloader UASP bluetooth docker eMMC i2c i2s m2 pci spi spi flash usb-c usb3 wifi wireguard Rockchip RK3588
Build Date: Oct 5, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.1.115 SHA  ASC 257.9 MB
Debian 13 (Trixie) Minimal / IOT rolling 6.1.115 SHA  ASC 268.6 MB
