Ubuntu Noble 24.11.1 GNOME Testing: | Rolling Release (25.2.x) Testing: |
- Images here are for 5B, for model 5A can be found here.
- Some eMMC devices are broken on 5A
- PD is broken for the 5B model (background) on most revisions that are in the wild and is causing boot loop. Workaround is to use a stupid / fixed 5-24 volts USB-C power supply.
- Installation to NVME or USB is done via standard armbian install utility (
sudo armbian-install
). Make sure to generate partitions and format them before start.
After you download and boot?
armbian-config
Build Date: Feb 26, 2025
Cinnamon | MESA / VPU | ![]() |
SHA | ASC | 1.4 GB | |||||
XFCE | ![]() |
SHA | ASC | 1.3 GB | ||||||
XFCE | ![]() |
Server images with Armbian Linux v6.1
Server / CLI | ![]() |
SHA | ASC | 497.2 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 231.6 MB | ||||||
Bleeding edge images with Armbian Linux v6.13
SHA | ASC | 1.5 GB | |||||
SHA | ASC | 265.1 MB | ||||||
XFCE | ![]() |
SHA | ASC | 1.4 GB | ||||||
SHA | ASC | 492.9 MB | ||||||
Gnome | ![]() |
SHA | ASC | 1.2 GB | ||||||
SHA | ASC | 260.5 MB | ||||||
XFCE | ![]() |
* Edge kernels are actively developed, so there may be some unreported issues on this images. You should beware of that. | * Most of images are tested with test automation or by Armbian community or official maintainers. |
Build Date: Mar 6, 2025
Distro | Application | Torrent | Integrity | Size | ||||||
Home Assistant | ![]() |
SHA | ASC | 331.9 MB | ||||||
Kali Linux | ![]() |
SHA | ASC | 500.1 MB | ||||||
OpenHab | ![]() |
SHA | ASC | 1.1 GB | ||||||
- join community forums
Build Date: Apr 21, 2025
Minimal / IOT | rolling | 6.1.115 | ![]() | SHA | ASC | 251.9 MB | |
Minimal / IOT | rolling | 6.1.115 | ![]() | SHA | ASC | 259.6 MB |
