rockpi4
Community maintained
After you download and boot?
armbian-config
Build Date: Mar 28, 2025
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.2 GB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 254.9 MB
1wire 2GB 4GB 6 core 64bit UASP bluetooth docker eMMC m2 usb-c usb3 wifi wireguard Rockchip RK3399
Armbian images and kernels can be made from scratch. Supported environment for build framework is any any X64 based Linux distribution. You can re-make live bootable image or just a kernel+dtb(hardware configuration) package which you transfer to your image and install with: dpkg -i linux-image-[branch]-family.deb linux-dtb-[branch]-family.deb. In that process you can enforce many customisation.
