Radxa Rockpi S0
Standard support
Minimal
Kernel: 6.12.15, Size: 268.9 MB, Release date: Feb 20, 2025
SHA hash | PGP signature
Stable user space packages
CLI
Armbian 25.2.2 Noble Server / CLI
Kernel: 6.12.15, Size: 445 MB, Release date: Feb 20, 2025
  • You may flash an OS image directly to the Rock S0 internal EMMC flash as follows:
    • Build Linux x86 binary rkdeveloptool (sources) on host
    • Remove any SDcard
    • Hold down the tiny, black MASKROM button while you…
    • Power on, with the MASKROM button pressed, to enter flash mode
    • Release the MASKROM button after 2 seconds
    • Next, run these host commands to flash the internal EMMC flash:
  • If a valid image is found on the built-in EMMC flash, the board will boot that image unless…
  • Holding down the MASKROM button disables the EMMC flash.
  • If no valid image can be read from EMMC flash, it will attempt to boot from SD Card.
  • The white “RECOVERY” button as no predefined function.
  • The Rock S0 has no “reset” button!
  • Kernel serial console is on UART0.
  • The serial console operates at 1.5Mbaud with 8 data, 1 stop, and no parity bits.
    Rock S0 serial console and power
  • Red(far right)=+5V, Black(center right)=GND,White(center left)=TxD, Green(far left)=RxD
There is no need to attach the +5V to the GPIO header (as pictured above) if the board is powered via USB.
If not using an external antenna, consider adding this line to /boot/armbianEnv.txt file to increase CPU clock to 1.3 GHz:
overlays=b@1.3ghz
However, use of an external antenna will dramatically improve radio performance.
If using an external antenna, consider adding this line to /boot/armbianEnv.txt file to increase CPU clock to 1.3 GHz and select the external antenna:
overlays=b@1.3ghz s0-ext-antenna
Refer to /boot/dtb/rockchip/overlay/README.rockchip-overlays for more information.
Audio Notes:
Linux kernel >= 6.12 with enable both the RK3308’s built-in analog CODEC and the pcm5102a CODEC used on other variants of the RockPI.
RockPI-S audio users should disable the pcm5102a by running the following command as root:
# echo "install snd_soc_pcm5102a /bin/false" >/etc/modprobe.d/blacklist-snd_soc_pcm5102a.conf
This prevents the kernel module for the pcm5102a from loading on subsequent boots.
To access the RockPI-S POE hat’s headphone audio output, please see:
https://wiki.radxa.com/ROCKPI_S_PoE_HAT
After you download and boot?
armbian-config
Build Date: Feb 20, 2025
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 259.4 MB
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 314.5 MB
Rockchip RK3308B
Build Date: Apr 16, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.12.23 SHA  ASC 260.2 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.12.23 SHA  ASC 280.1 MB
