rockpi-s
Standard support
Minimal
Kernel: 6.12.15, Size: 249.8 MB, Release date: Feb 20, 2025
SHA hash | PGP signature
Stable user space packages
CLI
Armbian 25.2.2 Noble Server / CLI
Kernel: 6.12.15, Size: 469.6 MB, Release date: Feb 20, 2025
  • If your RockPi-S is equipped a large enough SDNAND, you may flash an OS image directly to this internal flash as follows:
    • Build Linux x86 binary rkdeveloptool (sources) on host
    • Remove any SDcard
    • Plug the USB-C port into your computer
    • Hold down MASKROM button while you…
    • Power on or press the RESET button to enter flash mode
    • Release the MASKROM button after 2 seconds
      800px-Keys
      Next, run these host commands to flash the internal SDnand:
  • Holding the MASKROM button during reset prevents booting from internal the SDNAND.
  • But, the board will always boot from the SD Card, if it finds a valid image there.
  • Kernel serial console is on UART0.  [some older images have their console on UART2]
  • The serial console operates at 1.5Mbaud with 8 data, 1 stop, and no parity bits.
  • Black(left)=GND, White(center)=TxD, Green(right)=RxD
If you have a board with the -B version of the SOC, you may add the following line to your /boot/armbianEnv.txt file to allow operation at 1.3ghz:
overlays=b@1.3ghz
If you have a board with the BS version of the SOC, you should add the following line to your /boot/armbianEnv.txt file to tune for the newer “BS” silicon and run at 1.3ghz:
overlays=bs bs@1.3ghz
Note that the B version SOC is more common. I have never seen one.  The BS version supposedly will be labeled RK3308B-S.
Refer to /boot/dtb/rockchip/overlay/README.rockchip-overlays for more information.
After you download and boot?
armbian-config
Build Date: Feb 20, 2025
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 246.1 MB
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 315.3 MB
100tx 4 core 64bit bluetooth docker eMMC i2c i2s spi usb-c wifi wireguard Rockchip RK3308
Build Date: Mar 30, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.12.21 SHA  ASC 268.6 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.12.21 SHA  ASC 281.1 MB
