sakurapi
Community maintained
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 445.6 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 265.5 MB
Rockchip RK3308B
