Community maintained
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 249.1 MB
1000tx 1wire 2GB 4 core 64bit battery docker i2c i2s wifi wireguard Allwinner A64
Armbian images and kernels can be made from scratch. Supported environment for build framework is any any X64 based Linux distribution. You can re-make live bootable image or just a kernel+dtb(hardware configuration) package which you transfer to your image and install with: dpkg -i linux-image-[branch]-family.deb linux-dtb-[branch]-family.deb. In that process you can enforce many customisation.
