After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Gnome | ![]() |
SHA | ASC | 1.3 GB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 238.7 MB | ||||||
1000tx 16GB 4GB 64bit 8 core 8GB bluetooth docker eMMC i2c i2s m2 pci sata spi usb-c usb3 wifi Rockchip RK3588
- join community forums
