station-p1
Community maintained
In case of troubles booting, read this topic.
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.2 GB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 269.8 MB
1000tx 4GB 6 core docker usb-c usb3 wireguard Rockchip RK3399
