Texas Instruments SK-AM62B Development Board
Standard support
Minimal
Armbian 24.11.1 Bookworm Minimal / IOT
Kernel: 6.6.63, Size: 210.9 MB, Release date: Nov 23, 2024
SHA hash | PGP signature
Stable user space packages
CLI
Armbian 24.11.1 Noble Server / CLI
Kernel: 6.6.62, Size: 403.6 MB, Release date: Nov 23, 2024
After you download and boot?
armbian-config
Bleeding edge images with Armbian Linux v6.6
Build Date: Nov 23, 2024
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 204.8 MB
* Edge kernels are actively developed, so there may be some unreported issues on this images. You should beware of that.
* Most of images are tested with test automation or by Armbian community or official maintainers.
Build Date: Mar 6, 2025
Debian 12 (Bookworm) OpenHab SHA    ASC 1 GB
AM62X
Rolling releases images with Armbian Linux v6.6
Build Date: Apr 21, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.6.58 SHA  ASC 264.8 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.6.58 SHA  ASC 278.1 MB
