After you download and boot?
armbian-config
Build Date: Nov 23, 2024
Minimal / IOT | ![]() |
SHA | ASC | 204.1 MB | ||||||
Dedicated applications images with Armbian Linux v6.6
Build Date: Mar 6, 2025
Distro | Application | Torrent | Integrity | Size | ||||||
Home Assistant | ![]() |
SHA | ASC | 282.2 MB | ||||||
OpenHab | ![]() |
SHA | ASC | 1 GB | ||||||
- join community forums
Rolling releases images with Armbian Linux v6.6
Build Date: Apr 21, 2025
Minimal / IOT | rolling | 6.6.58 | ![]() | SHA | ASC | 262.6 MB | |
Minimal / IOT | rolling | 6.6.58 | ![]() | SHA | ASC | 278.1 MB |
