After you download and boot?
armbian-config
Build Date: Nov 23, 2024
Cinnamon | ![]() |
SHA | ASC | 1.4 GB | ||||||
XFCE | ![]() |
SHA | ASC | 1.3 GB | ||||||
KDE Neon | ![]() |
SHA | ASC | 1.5 GB | ||||||
XFCE | ![]() |
SHA | ASC | 1.2 GB | ||||||
Server images with Armbian Linux v6.1
Server / CLI | ![]() |
SHA | ASC | 444.6 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 203.4 MB | ||||||
Bleeding edge images with Armbian Linux v6.6
Cinnamon | ![]() |
SHA | ASC | 210.7 MB | ||||||
XFCE | ![]() |
KDE Neon | ![]() |
SHA | ASC | 438.6 MB | ||||||
Gnome | ![]() |
SHA | ASC | 206.1 MB | ||||||
XFCE | ![]() |
* Edge kernels are actively developed, so there may be some unreported issues on this images. You should beware of that. | * Most of images are tested with test automation or by Armbian community or official maintainers. |
- join community forums
Rolling releases images with Armbian Linux v6.6
Build Date: Apr 21, 2025
Minimal / IOT | rolling | 6.6.58 | ![]() | SHA | ASC | 263.9 MB | |
Minimal / IOT | rolling | 6.6.58 | ![]() | SHA | ASC | 278.3 MB |
