Standard support
Minimal
Armbian 24.11.1 Bookworm Minimal / IOT
Kernel: 6.1.112, Size: 208.2 MB, Release date: Nov 23, 2024
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 24.11.1 Noble Gnome
Kernel: 6.1.112, Size: 1.1 GB, Release date: Nov 23, 2024
After you download and boot?
armbian-config
Build Date: Nov 23, 2024
Debian 12 (Bookworm) Cinnamon SHA    ASC 1.4 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.5 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.2 GB
Server images with Armbian Linux v6.1
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 414.4 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 204.4 MB
Dedicated applications images with Armbian Linux v6.6
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 281.1 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1 GB
Rolling releases images with Armbian Linux v6.6
Build Date: Apr 21, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.6.58 SHA  ASC 266.5 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.6.58 SHA  ASC 277.1 MB
