tritium
Standard support
Minimal
Kernel: 6.6.75, Size: 241.9 MB, Release date: Feb 28, 2025
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 25.2.2 Noble Minimal / IOT
Kernel: 6.6.75, Size: 230.9 MB, Release date: Feb 28, 2025
After you download and boot?
armbian-config
Desktop images with Armbian Linux v6.6
Build Date: Feb 28, 2025
Debian 12 (Bookworm) XFCE SHA    ASC 1.2 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.1 GB
Server images with Armbian Linux v6.6
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 405.4 MB
100tx 1wire 32bit 4 core CAN UASP docker eMMC i2c spi wireguard Allwinner H3
