tritium
Standard support
Minimal
Kernel: 6.6.75, Size: 237.2 MB, Release date: Feb 28, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.2 Noble Gnome
Kernel: 6.6.75, Size: 1.2 GB, Release date: Feb 28, 2025
After you download and boot?
armbian-config
Desktop images with Armbian Linux v6.6
Build Date: Feb 28, 2025
Debian 12 (Bookworm) Cinnamon SHA    ASC 1.4 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.5 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.3 GB
Server images with Armbian Linux v6.6
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 456.5 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 231.2 MB
Dedicated applications images with Armbian Linux v6.6
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 299.4 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1 GB
2GB 4 core 64bit docker eMMC i2c spi wireguard Allwinner H5
