Udoo quad
Community maintained
After you download and boot?
armbian-config
Server images with Armbian Linux v6.6
Build Date: Feb 13, 2025
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 424.6 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 273.9 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 237.1 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 275.9 MB
1000tx 1wire 2 core 32bit 4 core docker i2c sata spi wifi wireguard NXP Freescale i.MX 6
