After you download and boot?
armbian-config
Build Date: Mar 27, 2025
Cinnamon | MESA / VPU | ![]() |
SHA | ASC | 2 GB | |||||
XFCE | ![]() |
SHA | ASC | 1.9 GB | ||||||
KDE Neon | ![]() |
SHA | ASC | 2 GB | ||||||
XFCE | ![]() |
SHA | ASC | 1.7 GB | ||||||
Server / CLI | ![]() |
SHA | ASC | 956 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 714 MB | ||||||
Cloud Images images with Armbian Linux v6.12
Distro | Variant | Type | Torrent | Integrity | Size | |||||
Minimal / IOT | (QCOW2) | ![]() |
SHA | ASC | 693.7 MB | |||||
Minimal / IOT | (Hyperv) | ![]() |
SHA | ASC | 760 MB | |||||
SHA | ASC | 652.4 MB | |||||
Build Date: Mar 6, 2025
Distro | Application | Torrent | Integrity | Size | ||||||
Home Assistant | ![]() |
SHA | ASC | 774.6 MB | ||||||
OpenMediaVault | ![]() |
SHA | ASC | 766.1 MB | ||||||
OpenHab | ![]() |
SHA | ASC | 1.6 GB | ||||||
Kali Linux | ![]() |
SHA | ASC | 1 GB | ||||||
Compatible
10000tx 1000tx 100tx 16GB 1wire 2 core 2500tx 2GB 32bit 4 core 4GB 6 core 64bit 8 core 8GB CAN ECC SPDIF UASP battery bluetooth docker eMMC esata i2c i2s m2 mpci msata nand pci sata sfp spi spi flash switch usb-c usb3 wifi wireguard
- join community forums
Build Date: Apr 15, 2025
Minimal / IOT (QCOW2) | stable | 6.12.23 | ![]() | SHA | ASC | 689.6 MB | |
Minimal / IOT (QCOW2) | oldstable | 6.12.23 | ![]() | SHA | ASC | 587.4 MB | |
Minimal / IOT (QCOW2) | oldstable | 6.12.23 | ![]() | SHA | ASC | 567.6 MB | |
Minimal / IOT (QCOW2) | oldstable | 6.12.23 | ![]() | SHA | ASC | 589.4 MB | |
Minimal / IOT (QCOW2) | stable | 6.12.23 | ![]() | SHA | ASC | 651.3 MB | |
Minimal / IOT (QCOW2) | rolling | 6.12.23 | ![]() | SHA | ASC | 632.9 MB | |
Minimal / IOT (QCOW2) | rolling | 6.12.23 | ![]() | SHA | ASC | 689.7 MB |
