Youyeetoo R1
Community maintained
After you download and boot?
armbian-config
Desktop images with Armbian Linux v6.14
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.2 GB
Minimal/IOT images with Armbian Linux v6.14
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 261.6 MB
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 313.2 MB
Debian 12 (Bookworm) OpenMediaVault SHA    ASC 318.7 MB
Rockchip RK3588
