zero-pi
Community maintained
After you download and boot?
armbian-config
Server images with Armbian Linux v6.6
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 391.6 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 244.5 MB
1000tx 1wire 32bit 4 core CAN UASP docker i2c spi wireguard Allwinner H3
